Spins but leaves a lot of water in the clothes.
Washer spins but clothes are heavy with water when spin is finished.
Check the condition of the belt and the belt tension. Should be about 1/2" deflection between main drive pulley and spin pulley. Tighten belt by loosening the two motor mount bolts, lever motor to the left and tighten bolts. Access via rear panel.
Eric
