washer
washer fill up with water but will not wash
fiil up with water but will not wash
Ihave a GE washer it will fill up with water but it will not wash
Remove the front panel and check the in line operational fuse for continuity. The fuse location is shown in the attached file.
If the fuse is fine, check the status of the motor green indicator light and post the results.
  • The fuse link AP4380189
Here are the breakdown diagrams and Replacement parts for General Electric WHDRR418G0WW Washer | AppliancePartsPros.com
P.S. I understand you are starving for your washer but multiple posts in the same thread would not do any good for you because it looks for other people like someone else already replied with a fix to the problem.
Fuse location and diagram.pdf (95.7 KB)
The signal LED location.pdf (61.6 KB)
Top load - unit disassembly.pdf (85.8 KB)
