We are getting a f-27 error code on the normal cycle pushed cancel door unlocked but when we opened door water came rushing out. Reset cycle to drain and spin then started normal cycle again now washer wont stop filling with water. Can anyone help:confused:
Perform the troubleshooting for this error code as described in the Tech Sheet (attached to the reply) and post the results. For more specific recommendations post the complete model number of the washer.
WFW8300SW01 wiring.pdf (178.6 KB)
