Washer won't start, lid latch light constantly flashes,
Brand: maytag
Model Number: mvwx600xw0
Main Symptom: won’t start, lid latch light flashing,
What happens & when: lid latch only latches when first plugged in then unlatches
Parts or tests already tried: replaced lid latch assembly, no change
Put the unit into a service diagnostics using the tech sheet inside the front panel of the washer. You will want to check to make sure that there are no error codes. If there are use the tech sheet to do the testing required for the error.
