I have the Frigidaire front load washer and went away on vacation. When I came back I washed 3 loads, and on the 4th load it stopped, wouldn’t spin or drain. When I close the door, it doesn’t lock, so the pause light flashes.
What could be wrong??
Hi.
Check if the striker on the door not broken
If it’s good - replace the door lock 131763202
Here are the breakdown diagrams and Replacement parts for Frigidaire GLTF2940FS2 WASHER | AppliancePartsPros.com
There is the chance that the control board is bad, but I’d change the lock first.
Simon.
