washer won't lock door and wring out clothes.
I started laundry load noticed the washer after few minutes had a electrical smell like something burnt and the door lock light was not lit. Let the load wash, after checking it several times. The lock light never did light up. Door would open and then when done the clothes were not wrong out very well. There was no visual water but the clothes were too wet to put in dryer. I tried several times to get it to spin out more. What do you think could be wrong?
My husband is handy and would like him to look at this before we have a expensive repair bill. Do not need that right now.
There are two control boards for this washer. The motor control board at the base of the washer and the main control board at the top near the timer.
I would check the top control board first. If the R11 resistor is burnt you would need to replace that board and the wax motor for the door lock.
http://appliancejunk.com/forums/index.php?action=gallery;sa=view;pic=1
Here is the service manual for your washer.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=1
