Washer won't drain
My washing machine was fine the other day…then I tried to was a small load and the machine went kaput. The machine made it through the wash cycle, but it is unable to drain.
I remember the machine spining for a few seconds…then clicking or humming…then nothing…then it would repeat (20 or so times). When I heard that, I thought it was odd behavior.
I unplugged it and plugged it back in…still can’t get it to drain. I thought I smelled something burning too.
I haven’t yet taken it apart to see what is the problem.
Any ideas where I should start? or should I just buy new? I think the washer was around $400 when I got it.
Thanks.
I just tried to get the washer to drain again. With the door open, I turned the dial to spin and held down the door switch. The machine did nothing…but hummed.
Next, I did the same but turned the dial to wash…the machine agitated!
So…I now know the door switch works…and it appears that the motor works.
Side note…I used a bucket to get most of the water out. While doing so, I found a few small pieces of gum and a gum wrapper. Hmmmm.
What do I try next?
Most likely the drain pump got stuck and has to be replaced. You have to remove the front cover to access the drain pump.
Here are the break down diagrams for the Hotpoint washer Model VBXR1060T5WB
