Washer won't drain and spin
The washer will fill and agitate slowly. When it gets to the rinse , drain and spin cycle it hums and does nothing. I bypassed the lid switch and it didn’t make a difference. What should I try next?
Remove the washer cabinet. Remove the pump from the motor and remove the motor from the washer.
Check all wires connected to the motor plug. With the motor plug in place put the motor aside, bypass the lid switch and check how the motor will work without any load. Post the results.
Here are the breakdown diagrams and Replacement parts for Whirlpool LSR8433KQ0 WASHER | AppliancePartsPros.com
How to remove the washer cabinet.pdf (43.7 KB)
How to remove the pump.pdf (42.3 KB)
How to replace the motor drive coupling.pdf (39.5 KB)
