Washer won't agitate
Washer will not agitate makes a loud sound when in the spin cycle that sounds like something is stripped. It goes through all cycles but never agitates. Please help:cool:
The first failure suspect is the motor drive coupling (#13 on the diagram). The complete instructions are attached.
  • The part number for the motor drive coupling is AP3963893
Here are the break down diagrams for the Whirlpool washer Model LSR8133HQ0
How to replace the motor drive coupling.pdf (39.5 KB)
How to remove the washer cabinet.pdf (43.5 KB)
How to remove the pump.pdf (42.3 KB)
