Brand: Admiral
Model Number: ATW445VQ1
Main Symptom: does not spin
What happens & when: Will not spin in the spin cycle. Water drains with no problem.
It would be recommended to put the unit into the service diagnostics mode to see if there are any stored error codes. The error code will guide you on what to check. The tech sheet can be found under the main top at the front of the cabinet.
The Admiral washer does not have a front panel with lights that I believe will determine the codes. Is there another way to receive the codes if placing the machine on diagnostic mode. Thank you.
