My Signature washer will wash clothes great but will keep on washing right through the drain/rinse and spin cycle until the final drain and spin cycle.
I tried to look up the model number but didn’t find anything. The serial number is XC54223469.
The washer said Signature on the control panel but says “Frigidaire” and “White Consolidated Ind” where the model number is written.
[COLOR=#ff0000]CORRECTED MODEL NUMBER MWL111RBW2[/COLOR] [COLOR=#ff0000][/COLOR] [COLOR=#ff0000]Sorry for the confusion[/COLOR] [COLOR=#ff0000][/COLOR] [COLOR=#ff0000]tempo1001[/COLOR]
TO whom it may concern, I have a Kenmore Heavy Duty Extra Large Capacity Plus washing machine. Model # 110.22292100, Serial # cm 2937753, Type# 107 . The washing machine goes through the partial rinse cycle then just stops. It does not advance at all. Just stops completely. It happens on all wash cycles, same thing. Could this be the timer or the door lid switch or both? Thanks for any light you may be able to shed on this delima. Doug M.
I have the same problem as hammer33 above in this thread. How does one discern between a failing lid switch or a timer? My machine stops in the middle of the cycle, on all different washes.
