Washer will not rinse/ new timer replaced
amana topload washer, replaced timer, bought from appliance parts pros. Completed simple plug in installation now washer will complete wash cycle but will not rinse clothes. removed the new timer and compared to the old one and both are identical, order # was 861866 from appliance parts.
please advise, wife is getting grouchy
Boy I hate it when that happens.
You need to tell us in more detail exactly what happens, does the machine just stop when it gets to a certain point in the cycle, and does this happen on all cycles?
Also, have you checked the lid switch? You can by-pass it to test it out and see if that is the problem.
Finally, what led you to replace the timer.
will only go to a certain spot in the cycle than stop. Will complete the wash cycle only and stop, no rinsing. ( on all cycles )
Have you checked the cold water supply?
Washer will fill with water,wash clothes and spin but will not rinse ( next step in the wash cycle).The timer is new, bought from your company, is it possible that the purchased timer is bad. There were two recommended timers for this brand of washer, Amana model lwa50aw, but no one could tell me what the difference was between the two. The one I purchased had the same h/p and cycles as the old one I removed.
I spoke with Eric in customer service and he said that he would send me out a new timer right away but I still would like to know the diffefence between the two advertised.
Cold water supply is ok. Old timer was replaced because when the button was pushed in there was no clicking sound when the knob was rotated
Cold water supply is ok. Old timer was replaced because when the button was pushed in there was no clicking sound when the knob was rotated.
How do you get to the timer in the control panel of my kenmore washer?
To Allen P
Please start a new post with your full model number and tell us exactly what your problem is and what you want to do.
Hi Bak
A couple of things. Those of us who respond on this are not associated with APP (unless so stated). We are volunteers who try to answer the questions and solve the problems as best we can. I think APP gives great customer service, their prices are good and the delivery is as fast as anyone at a great cost and that is why I like to participate in this Forum.
As far as the two different timers for your model is concerned, they are both the same, a less expensive version is sold under the Speed Queen brand. There have been some reports that the Speed Queen product is not as good as the others.
Since your machine does go through a complete cycle of agitate, drain and spin it does sound like your replacement timer was also defective so I hope the new one will solve your problem.
Kenmore washer. model 110.28422700 type 111-07 I have the timer I just can not get in the control panel from the back or sides. I need to know how to get the top control panel open to instatll the timer.
Allen
If you will insert a putty knife under the control panel where it meets the top near the edges you will be able to release the clips that hold it to the top.
