Washer will not fill
Brand: Maytag Bravos XL
Model Number: MVWB765FW0
Main Symptom: Will not fill with water
What happens & when: Barely fills when cycle starts
Error Code (if any): F3 and E2
Parts or tests already tried: Replaced the inlet valve and wiring harness
Hi Kengleka, thanks for the info.
The F3E2 error code on your Maytag Bravos XL indicates a water temperature sensor failure. Since you’ve already replaced the inlet valve and wiring harness, and you’re still seeing low water levels and the same error, it’s unlikely this is a mechanical issue.
At this point, based on the process of elimination, it points to an electronic failure—most likely the main control board.
Here’s a link to the part information page for the correct main control for your model:
:backhand_index_pointing_right: Main Control Board – W11611438 (AP7210082)
Let us know if you need help with testing or replacement steps—we’re happy to assist further!
Thank you! I appreciate you taking the time to respond and letting me know what the issue probably is.
