Speed Queen washer will not fill after replacing fill valve
Todd,
A model number would be a lot more helpful.
In general, if you’ve replaced the fill valve, and you have no broken, loose wires, the next step is to test:
the lid switch,
then the water level switch,
then the timer circuits in the fill increment.
