Washer will not agitate or spin
The washer will not agitate or spin. It will drain the lid switch I think is good and the coupler is good. I think the clutch or transmission has a problem. I have taken them off nothing look broken. What else could be wrong?
Since it will drain this means the motor is working and the lid switch is ok.
This really sounds like a coupling problem. I would change it out. Sometimes a problem is not visible unless you take it apart.
The coupler is not broke I have taken it apart and looked at it I have also t as Ken the transmission apart and do not see anything broken but the gear on the shift did not want to move freely it was very stiff we freed it up it still does not work any suggestions.
If the outer case of the clutch is not turning when the machine is supposed to be agitating or spinning then that would suggest the transmission is the problem. If it were only the clutch it would agitate but not spin.
