Washer water fill does not stop
Brand: WHIRLPOOL
Model Number: WTW4955HW2
Main Symptom: WATER FILL DOES NOT STOP
What happens & when: WATER CONTINUES TO FILL (overfill)
Try unplugging the machine, if the water stops the issue is the control is still appling power to the valve. If the water does not stop when the machine is unplugged, the issue is the inlet valve.
[AppliancePartsPros.com]
(Washer: Troubleshooting Common Washer Problems & Solutions)
