The washer tub is leaning to the right and slightly forward. It is very loud and is starting to move around the floor. I changed the 3 suspension springs and the balancing spring. Nothing changed after changing the springs. What else could the issue be? Possibly drive block??
Is this spring still in place?
Whirlpool WPW10250667 Suspension Spring - AppliancePartsPros.com
Video
Washer Tub Counter Balance Suspension Spring (part #WPW10250667)-How To Replace
All springs are still in place. The three suspension and the balancing spring.
How about parts 13, 14, and 15 on this diagram? are the in good shape and lined up right?
Parts for Maytag MTW5700TQ0: Machine Base Parts - AppliancePartsPros.com
This video might help.
Washer Suspension Pads (part #285744) - How To Replace
If you could post some pics or a video of the problem that might help.
After looking at it closer this morning, the front right metal leg has a white powder substance. This is the side it’s leaning to. I’m guessing the suspension pad is badand wore down. I’m going to order a set of 13 and 15. Skate plate itself looks fine.
