With the washer in standby, rotate the cycle knob using this pattern with a half second pause in between movements. Rotate it counter clockwise 1 click, clockwise 1 click, clockwise 1 click, clockwise 1 click, counter clockwise 1 click, then clockwise 1 click. All of the LEDs should flash and the cycle knob can be rotated clockwise 1 click, changing the LEDs to only the Done LED being illuminated. Press start when the Done LED is illuminated and it will enter into a fault code display mode. Once entered, rotate the cycle knob clockwise one more time. The status LEDs should now flash in a pattern. What LED pattern flashes each time?
