I’m not sure if the timer is bad . The washer will stop mid cycle but if I move the timer button to the side a little it will continue where it has stopped . The washer fills ,agitates spins and drains, but I have to get it started when it stops. Otherwise everything works.
That very well could be unfortunately on this model there are no way to visibly check the timer without breaking it. I believe it’s a solid plastic box. Does it do this on every cycle?
