Washer still not working after pressure switch replacement
Brand: Whirlpool
Model Number: WFW85HEFC1
Main Symptom: error codes
What happens & when: not draining properly, shuts down, door locked
Error Code (if any): E01, F03
Parts or tests already tried: Water level pressure switch, cleaned drain.
Hello, can you give me a little more information as to why you replaced the pressure switch? What is the washer not doing? Will it drain out all the water? Is it overfilling?
Site stated with these error codes to replace pressure switch first. Yes, water is not draining all the way out. when I unplug it to reset, and plug back in it sounds like it is trying to pump? hose jumps and a little water comes out? Tried a small load of clothes and they are completely soaked yet. Placed on drain and spin and error codes come back up again. E01, F03. Thanks
Have you gone to the pump clean out and removed the coin catcher/pump filter? If the water does not drain out, something is restricting it. I would start at the pump clean out.
Yes did all of that. Drained and water came out. Cleaned, blew on small line to pressure switch, felt air coming out. Basically, did everything site said and still does not work right. Wondering if pump problem or console?
Check the impeller on the pump motor. You should be able to hear the pump motor running when it is in a drain mode. I would not worry about the pressure switch, it is being tripped because there is too much water in the tub. The impeller should not turn independently of the metal shaft or it is stripped.
I have it off, impeller turns free about 3/4 away around then catches. probally order pump motor kit?
