washer skiping cycles
I just installed a new control panel that I received today the F1 code is gone but it now skips from 34 to 4 fills then drains and never washes did I get a faulty part or is it something else?
That would be highly unusual, but that sures sounds like what happened. Is this symptom the same as before you changed things out. If not, maybe the new unit is bad.
