Washer Will not start. at one time push start button several times washer would start. now will not start.
Okay, this model has an error code generator using a blinking light that is on the inverter that is on the motor.
Here is a guide to interpreting codes.
HydroWave GE Washer Repair Guide
First do a reset, sometimes that is all that it needs.
red light doesn’t stop blinking. Could not reset. Thanks for info
0
