washer repair
Washer agitator stopped working suddenly, on rinse cyle makes a constant loud noise
Remove the washer cabinet and check the motor coupling (#13 on the diagram). The instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KAWE667BWH1 | AppliancePartsPros.com
How to remove the washer cabinet.pdf (43.5 KB)
How to remove the pump.pdf (42.3 KB)
How to replace the motor drive coupling.pdf (39.5 KB)
