Washer Repair
The washer will not engage the Rinse or Spin Cycle. It agitates, but will not drain when I turn it on the Rinse Cycle nor will it Spin on the Spin Cycle. The washer will agitate on each washer setting, but it will not drain on Rinse Cycle nor will it engage on Spin Cycle. Thank you for your help
Charles[FONT=Times New Roman][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
[quote=crispress;292393]The washer will not engage the Rinse or Spin Cycle. It agitates, but will not drain when I turn it on the Rinse Cycle nor will it Spin on the Spin Cycle. The washer will agitate on each washer setting, but it will not drain on Rinse Cycle nor will it engage on Spin Cycle. Thank you for your help
Charles[/quote]
Charles,
I believe you used the wrong number(I think you used the serial number instead of the model number),
Please recheck and supply the proper model number.
What kind of noises, if any does the machine make when the dial is in spin/ drain or rinse cycle ?
Thanks,
WEBSITE: www.golfdiscount18.comLOFTS: 6-iron: 29, PW: 45TECH TALK: A thinner face and a wider sole on the G15 are two noteworthy upgrades from its G10 predecessor. Another one is the reshaped and repositioned custom tuning port that saved seven grams of weight, which designers moved to the perimeter to boost stability.PLAYER COMMENTS:(H) “A really easy club to swing. You don’t have to force a thing.”(L) “It looks like something you’d find on your workbench, but the hit is impressive. It’s the most forgiving thing I’ve tried.”(M) "It has the high trajectory this type of iron demands. I’ve hit good shots with other clubs, but with this I’m hitting exceptional shots."Welcome our website(discount golf cllubs)
