Washer refills after spin cycle in all cycles
I have a washer that refills after the spin cycle in all cycles except Quick Wash cycle. I ordered and replaced the timer, and still have the same problem unless I set it to spin again.
What next?
Disconnect the hose from the back of the fabric softener switch and blow into the hose to make sure it’s clear. Cut 1/4" off the end of the hose and reattach. If that doesn’t fix it, replace the switch.
Whirlpool W10292584 Switch-Sen - AppliancePartsPros.com
Eric
What does the softener switch have to do with the spin cycle? They seem unrelated. I guess I will need to return the timer, since it wasn’t the problem. I will check the hose and hopefully it will work without replacing the switch.
Thank you for your help.
It’s more than just that, it’s a load sense control. It contains a circuit board with pressure sensor and receives input signal from a water flow sensor. It controls the water inlet valves via the temp switch. It is a high failure item on these washers and causes the exact symptom you are having. Another symptom can be that it starts agitating while filling.
Eric
It does that too forgot to mention it. So is it the switch or the sensor or is it the same? I trimmed the hose and did a load of wash and still has water in the bottom at the end of the cycle. I ran a spin cycle to empty it.
Does that mean it wasn’t the timer and can send it back?
Thank you for your help!
Wasn’t the timer, replace the switch (link I gave to you).
Eric
okay Thank you Eric!
Deb
