Washer overflows
During the fill cycle, water does not shut off when tub is full, washer overflows.
With washer empty, open the front panel, disconnect the pressure hose from the air chamber on the lower left side of the tub and clean out any gunk in the hose. Use a turkey baster with hot water to flush out the air chamber of any gunk as well. The air chamber is not removable.
Eric
Thanks, you were on the money…hose was plugged with junk for about 6 inches…cleaned it all out, washer works fine again!
