Washer out of balance unloaded
Hello,
I purchased this machine used, and when I set it up and tested it in my garage, I immediately noticed that, during the spin cycle, the basket wobbled as if it contained a slightly off-balance load. When I run the machine, it moves several inches during every load
Do any of you have advice on how I might correct this problem?
Thanks!!
Chuck
Sometimes when you move the models it takes a few runs for them to set up right. If it doesn’t correct itself after a couple of runs take off the cabinet, by-pass the lid switch and operate and see if you can detect the problem. If all else fails replace the springs, it is an inexpensive fix and sometimes there is a problem that cannot be seen.
