Washer off-balance in Spin Cycle
The washer start to be off-balance in the Spin cycle. The tub start to hit the sides and make a loud metal-wall sound. I verified the Suspension rods, and for my opinion, it look pretty well. I verified the Drive block and I don’t see any worn on it. But when I carefully move the basket with my hands, I notice that the basket (internal) wobble a little, but maybe this is where my problem is, because in high speed this wobble can increase vibration.
So, I’m confuse if I need:
  1. Suspension rod
  2. Drive Block
  3. A New Basket
I’m already verified the level and the leveling legs and they are good. Then here are my questions:
  1. How I determine that one suspension is defective? Excluding if one Rod is bended. What other kind determine a bad suspension?
  2. Why my washer did not have spring from the rod to the tub like other similar models I see?
  3. Is normal that basket wobble a little like 1 inch when it is tight with the spanner nut?
Thanks!
Help Please
Thanks for the help! I appreciate it a lot.:mad:
