Washer not ringing out
Clothes are not rung out without running a second spin cycle. I have replaced the clutch assembly and still ahving same issue. Any Ideas?
Operate it with the cabinet off by by-passing the lid switch. Looks to see how fast it is spinning and check out the internal drain hoses and pump for some blockage. Finally check to make sure the brakes are releasing as they should.
