I have a Maytag MVW6200KW. It was great at first but now it seems to not get my clothes as clean. can I change agitator wash plate to a more traditional agitator?
Brand: Maytag Model Number: MVW6200KW Main Symptom: Clothes don’t seem to be getting clean enough anymore What happens & when: Cycles are a lot longer? Soap residues are on clothes after wash (just started doing this).
The first place to start is try to clean the machine if there is soap residue after the cycle completes. Also check to make sure that the unit is going through the final rinse as well. This could be an issue with the unit not getting cold water and not going through the final rinse and spin. If there is no cold water coming in then check the screens on the water valve to make sure they are clean. If this is good then put the unit into service diagnostics and see if there are any error codes. This would guide you to what may be going on.
Ok so you have 4 different error codes, one would be an F0E3 which is an overload meaning that the unit has been overloaded. The second would be and F7 E1 Tachometer missing or wrong signal, the next F7 E6 Motor Circuit Open and last F7 E7 Motor unable to reach target RPM. It would be recommended to do a circuit test on the main control and drive system.
