Washer will not turn on. Turned the machine on and left the house. When we got back the machine had partially filled with water and turned itself off. Now it won’t turn on at all. Tried a different receptacle and still doesn’t work. What do I replace? The power cord or the control panel?
Hi.
Open the control panel, locate and check the fuse. If it’s blown - replace the lid switch assembly AP6006235
Here are the breakdown diagrams and Replacement parts for Maytag LAT9206AAE WASHER-TOP LOADING | AppliancePartsPros.com
Thank you. Post the results.
Simon.
