I HAVE A BAD COUPLING. NOT SURE HOW TO REPLACE. DO YOU REMOVE TRANSMISSION? HELP!!! MARK:confused:
Just remove the outer case of the washer, remove pump, and motor. Pry off the bad coupler and pound on the new one. Turn the tranny coupler clockwise till the spin basket just starts to turn. If hard to turn the coupler with thumb and forefinger, you have other problems. Post results.
