Washer lid seal replacement
The lid seal on my washing machine (Whirlpool gold) has come off. Someone previously had glued it but I am sure that is not the way it needs to be installed. I am going to order a new one since this one seems stiff.
How do I attach it? Does it need some sort of glue or does it just fit on the lip?
Thank you in advance for your help
If you will post a model number someone of the Forum may be able to help you.
[QUOTE=sidfink43;291276]If you will post a model number someone of the Forum may be able to help you.[/QUOTE]
MODEL number is GSX9885JQO
