Washer leaves water in drum
My kenmore seems to lave water behind after a cycle is complete. The washer will spin and the clothes are not soaking in the water. The water seems to be outside of the main washing compartment. My question is, how to I drain this excess water and what could be causing it stay in the washer? I dont even know where the water is b/c when I look inside the washer there is no water. If I tip the wash slightly I can hear the water slosh back and forth.
Thanks for the help :slight_smile:
If I understand you, the washer is washing and spinning out clothes OK.
It is just this water that is concerning you.
Click on the below picture and read the Q&A section.
AP6017208
