I will only be here 5 days.
An elderly lady says her washer is leaking possibably when it it set for (extra large load). As I moved the washer there
was puddled water under the unit.I placed paper under the whole washer. I ran an “extra large” cycle without the clothes.
The results were; no signs of water. Is there a common part that is normally replaced in a situation like this or are there more checks/tests I need to prefom? Your expertise in this matter will be greatly appreciated. Thanks!!
LITTLE HOUSE;739271][FONT=Comic Sans MS][COLOR=blue]I will only be here 5 days.
An elderly lady says her washer is leaking possibably when it it set for (extra large load). As I moved the washer there[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=blue]was puddled water under the unit.I placed paper under the whole washer. I ran an “extra large” cycle without the clothes.
The results were; no signs of water. Is there a common part that is normally replaced in a situation [/COLOR][/FONT][FONT=Comic Sans MS][COLOR=blue]like this or are [/COLOR][/FONT][FONT=Comic Sans MS][COLOR=blue]there more [/COLOR][/FONT][FONT=Comic Sans MS][COLOR=blue]checks/tests I need to prefom? [SIZE=1]Your expertise in [/SIZE][/COLOR][/FONT][SIZE=3][FONT=Comic Sans MS][SIZE=1][COLOR=blue]this matter will be greatly appreciated. Thanks!![/COLOR][/SIZE][/FONT]
[/SIZE]
