washer leaking in the front when in use
washer leaks in the front but, the operation of the washer is fine.
The most common cause would be the pump leaking, which is located front dead center on that style of washing machine. However you may have a leak somewhere else that happens to be running out the front because of the slop of the floor. best thing to do is pull the cabinet and take a look.
here is a link to some videos on repairing that style of washer.
Washer Water Drain Pump Repair Video
