Brand: Admiral
Model Number: ATW4675YQ0
Main Symptom: loud roaring noise on final spin cycle
Brand: Admiral
Replace the gearcase, W11454741 Washer Gear Case | Genuine Whirlpool OEM In Stock, there are no separate bearings in the tub, just the gearcase
I need to change the entire gearcase to fix it? I looked it up and I see a bearing kit for whirlpool washers (my washer is made by Whirlpool). Can I just run it like this until it dies?
Sure can, I have got to the stage of life when it needs major repairs, I buy another one, get the longest extended warranty I can. There is so much when it comes to repairs nowadays because of all the electronics; they can be complex to repair. By the way, you need to look at your model; there is no bearing kit, it has a seal but no tub bearings. The noise that may sound like a bearing is the gearcase.
