Washer gearbox seal
was replacing clutch and found gearbox oil on it. the shaft wobbles a little, should it? can that seal be replaced?
There are two seals to replace. One for the transmission cover and another inside the spin pinion gear. You will also need a tube of gasket sealer to reseal the transmission cover.
Whirlpool 3349985 Shaft Seal - AppliancePartsPros.com
Whirlpool 356427 Shaft Seal - AppliancePartsPros.com
Whirlpool 285195 Gasket Sealer - AppliancePartsPros.com
Eric
