Washer fills while spinning
LG washer changed the water valve that has four solenoids, this was the problem according to the error codes. No code now but it is filling with water while spinning and i can hear one of the four valves operating while in spin cycle. How do i test my valves properly? what could the issue be?:frowning:
Is it the actual spin cycle or just the rinse cycle?
