Washer fills than drains
Brand:GE
Model Number:GTW465ASN2WW
Main Symptom:ONLY FILLS AND DRAINS
New water valve and drive belt, passes all test, does not do the recirculate valve test, not sure it has one.. Washer fills and than immediately drains
Check the pressure hose to make sure that it is not clogged. If it is not then put the unit into service diagnostics and see if there are any error codes.
YTW4514PNDG 31-3000374 (1).pdf (322.5 KB)
Thanks for the tip. It appears I dislodged the pressure hose when installing the water valve assembly. Up and running!! Thanks much, you ARE the pros!
