:eek: HELP!
Mywasher fills & drains at same time when gets to rinse cycle and I need an answer how to fix this. The quick fix is at the rinse cycle pull the tub forward just a bit and it will stop draining. Is it the horizontal and verticle springs? A problem with the pump? I NEED ASSISTANC EASAP PLEASE BEFORE THE WATER PUMP FOR MY WELL BURNS OUT FROM BEING LEFT ON BY THE WATER FILLING.
Remove the front panel and open the control panel. Check all wires.
Here are the break down diagrams and Replacement parts for FRIGIDAIRE FWS235RFS1 | AppliancePartsPros.com
