Washer filling with water... when not on
So our washer decided it wants to fill up its basket with water when it is not turned on. I could hear water going into the machine back by the water inlets on the back panel. I shut the water supply off and I could not hear it. So somewhere water is has found a way to get into the basket. Has anyone had this happen? Is there a seal that has gone bad? Maybe a filter that needs to be cleaned? I am heading down to investigate it now but wanted to hear what others have to say.
Thanks in advance! -Bob
Bob,
Sounds like the problem is a bad water inlet valve. If you need more specific information, post the complete model number of the washer.
Thanks Gene! After actually taking the lid off the washer and looking at it, that is pretty much what I thought. I did a search on here too and found that came up a lot. It is nice to hear someone else say that yeah that is probably what it is. I will get a new one and replace it, and report back on the outcome!
Just for reference sake… model No. 110.42932200. Part No. 8181694 (per machine parts manual) - Inlet Valve
FYI This is my first attempt at fixing a major appliance in my house, so it was a nice learning experience.
Yes, the part number you posted is the correct part number.
Whirlpool part number 8181694 is Appliance Parts Pros AP6011714
Good luck.
