The washer was in the rinse & spin cycle, it became unbalance, and just cut off. We found out it blew a breaker, new breaker replaced. Dryer will work, but washer will not do anything when control knob turned to cycle. It will NOT even begin to fill up with water. Do you know what could be wrong?
Take out the console and check to see that power is coming into the console using a multi-meter.
If so, sounds like something blew out the timer so try replacing that.
