Brand:
Model Number:
Main Symptom: installed new drive belt, drum still not agitating or turning
What happens & when: new belt installed, can manually move drive belt underneath tub, not working when washing machine is running…HELP
Washer make?
Washer model#? Some model# helps… Where is my Model Number? | Appliance Aid
The washer runs when it should be agitating and spinning?
jeff sr.
GEmodel WSR3140GOWW realized the washer was not spinning. I ordered a new drive belt when I discovered the belt was broken. Finally got the new belt installed properly. washer fills and empties but does not spin on any cycle. Checked to see if the belt turned the large pully and it does. HELP
PS It des not agitate either
WSR3140GOWW
This is coming up as a refrigerator. Are you reading it off of the tag on the washer?
If the belt and pulleys are moving but no agitation or spin….kinda sounds like a bad gearbox/tranny
jeff sr.
