Brand:Maytag washer Model Number:LAV3600AWW Main Symptom:tub leak drain nipple What happens & when:flare on bottom of nipple rusted way. Can I cut away rust, apply rtv silicone and attach new hose to repair. Or just trash washer. Appreciate.
I’m not sur after you cut that off that you will have enough left to attach to. Also if that is rusted I’d be worried about other rusty places in that tub. The tub assembly ( Whirlpool 22001114 Washer Tub, Outer Ex/Large No Longer Available. | Genuine OEM Part ) is no longer available. As far as scrapping it and getting another one that is entirely up to you.
