The Washer Does The Final Spin But Clothes Are Still Coming Out Wet Not Soaking Wet. It Is Not Spinning Fast Enough Any Suggestions
Which cycle did you use?
How much clothes were inside the washer?
Did the washer was shaking during the spin?
Did it make any unusual noise?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSQ8520JQ1 | AppliancePartsPros.com
washer makes a high pitch then louder noise while spinning and leaves too much water in the clothes, I was washing a med load
Remove the washer cabinet and the pump. Remove the hoses from the pump and check for a foreign objects inside the pump and hoses.
How to remove the washer cabinet.pdf (43.5 KB)
How to remove the pump.pdf (42.3 KB)
it doesnt matter what cycle or how many clothes i had the lid lifted and it doesn’t seem to be spinning as fast as it should and I heard a noise like something was rolling around in it
Remove the washer cabinet and check the motor coupling. Check for a foreign objects between the inner and outer tubs.
