Washer does not spin or agitate
i have checked and the fuses but still will not spin or agitate
Hello,
Does the motor run?
Watch the status LED on top of the motor, bellow the inverter and post the results.
Here are the breakdown diagrams and Parts for GE WBSR3140G1WW Washer - AppliancePartsPros.com
yes motor is running
[quote=Gene;799240]
Watch the status LED on top of the motor, bellow the inverter and post the results.[/quote]
What about the second question?
do not see LED what dos it look like also what does inverter look like?
The inverter is located on top of the motor.
Hopefully the attached picture will help you to locate the LED.
The signal LED location.pdf (61.6 KB)
