This is posting for a friend with above washer.
Symptom is:
Water does not drain fully when washing, the cycle will not finish without someone having to press start again and the water smell.
What should we do???
TIA.
Symptom is:
TIA.
Perform the service tests as described in the attached manual and post the results.
Here are the breakdown diagrams and Replacement parts for General Electric WBVH6240F0GG Washer | AppliancePartsPros.com
Service test mode and error codes - WBVH - WHDVH.pdf (1.1 MB)
