Washer circuit board programming lights
Brand:ge
Model Number:Gtw335asn2ww
Main Symptom:skipping cycles
Thanks for the information. Is there any additional detail you can provide about what happened when the washer started skipping cycles? For example, did it stop at a specific point in the cycle, display any error codes, make any unusual noises, or have trouble filling, draining, or spinning? Any details you can share will help us better understand what may be causing the issue.
