Washer agitating while filling and doesn't fill
Brand:Kenmore
Model Number: 417.94712400
Main Symptom: agitating while water is filling. Also spins slowly
What happens & when: When you put the washer dial on the cycle with the number 8 it begins agitating while filling, and does not actually fill the tub.
Hi, normally, a bad pressure switch or a clogged pressure hose can cause the washer to start agitating before it fills because the machine thinks there’s already enough water in the tub. However, since your washer works properly on every other cycle and only has this issue on Cycle 8, I would suspect the timer rather than the pressure switch.
The timer has internal electrical contacts that control when the washer fills and agitates. If the contacts for Cycle 8 are worn or damaged, the washer may start agitating before filling with water.
I would recommend checking the timer first, along with its wiring connections. If the wiring is good and the timer isn’t sending power to the water valve when it should, the timer may need to be replaced.
It’s not working on the other cycles it drains when it should be washing and the guy we bought it from replaced the timer
Hi, I would recommend double-checking the part number to make sure you have the correct timer for your washer. It seems like the timer may not be the right one for your model, which could explain the issue you’re having. I would start by comparing the timer’s part number with your washer’s model number to confirm they’re compatible
